PRE-H20's Avatar
JUST finished..............................
Old 06-22-2020, 12:25 PM
Kurt
Originally Posted by AG81 View Post
This is a really sharp look, might be favorite in this thread. Any info on the build?
Old 08-22-2020, 01:46 PM
7783911's Avatar
frunk redo
I redid the entire frunk (cleaned, painted, wiring redone etc) and then added this coco carpet using snaps
Old 08-26-2020, 03:37 AM
Driver, not Mechanic
Sorry to revive an old thread. It is frunk related. Is there a replacement / better cover than this? Mine is looking worse for wear. (I did see another photo that just left it uncovered. I suppose that's ok too...)
Old 08-09-2024, 08:54 PM
I just added a cargo net under the carpet in front of the separator for the blower assembly to hold the aftermarket air pump - so nothing floating around ...
Old 08-09-2024, 10:59 PM
khamul02's Avatar
pad keeper?
The guy who made the pad keeper I think made a nicer cover:
David Etter
https://www.facebook.com/david.etter.3
https://forums.pelicanparts.com/porsche-964-993-technical-forum/1027598-pad-keeper.html
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 08-09-2024, 11:20 PM
From this:
To this: following the style of the old Rallye-cars
Old 08-10-2024, 12:32 AM
Detail:
Old 08-10-2024, 12:40 AM
I'm good with tools.
AG81's Avatar
Ken
This was my car I sold in October.
Build here.....https://forums.pelicanparts.com/porsche-911-technical-forum/1002364-85-outlaw-build-thread.html
Curently work on a 72.......
Build here..........https://forums.pelicanparts.com/porsche-911-technical-forum/1147478-72-build-thread.html
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
13 991.1 Coupe 2S 3.8L (currently undergoing mods)
02 996 4S
Old 08-10-2024, 09:14 AM
AG81's Avatar
02 996 4S
Old 08-10-2024, 09:21 AM
Old 08-10-2024, 09:41 AM
Wild thing -
I’m not sure what the original cover is made of or if there’s a factory part number, but it’s like a paper fiber/plastic composite.
Always a good idea to protect those brake lines from any accidental damage.
Some thin aluminum sheet metal like roof flashing is easy enough to cut to match pattern and put into place.
Or you can buy a 12x12” sheet of Kydex about .30 in thick, use your old cover as a template, cut the shape with a decent sized snips or scissors. I’ve made a cover to patch a hole in my bulkhead when removing the AC.
Good thing about Kydex is it can be formed and shaped to contours with heat (hair dryer, hot towel, soak the Kydex in hot water, etc) and it stays put with no curling up at the edges, just re-heat until shape is at desired position.
Prime and paint to match if necessary.
Old 08-10-2024, 09:47 AM
proporsche's Avatar
mine is being used ;-) no need to have it empty;-)
1985 911 with original 502 191 miles...808 198 km
Old 08-10-2024, 11:59 AM
I’ll play. I learned how to use a sewing machine and made this
____________
'84 911 Targa
Old 08-11-2024, 04:48 PM
7 inch wheel with a 215 tire as a spare, so cardboard under the carpet neatens the original look.
'56, '59 356A Coupes
'67, '68 912 Coupes all gone
'72 911T coupe
Old 08-16-2024, 07:01 PM
