Originally Posted by betterair View Post
The backdate heat comment ,was probably meant to suggest/recommend installing SSI heat exchangers ,which are said to be a very good addition to the sw chip for optimizing performance.
I would really like to see a comparison of the ssi 's vs the Fabspeed system the op is running.
Ah I see! The Fabspeed set up is just temporary for a year or so. The PO had a muffler on there that was welded up from something and it was touching the whole bumper on the inside and baking the paint. I just wanted a quick fix while I researched.
Speaking of research, I heard the SSI set up is not good for the 3.2? It's undersized if I recall?
I am thinking about the 993 heat exchanger route.
Jase.
Jason Herriott
1986 951 (5 Speed) - Zermatt Silver Metallic / Black
1987 928 S4 (Auto) - Cassisrot Metallic / Burgundy
1988 911 (5 speed) - Silver/ Burgundy
1986 930 (4 Speed) - Oak Green Metallic / Cork (Wish list! )
Old 10-20-2017, 03:38 PM
Originally Posted by Franks89-911 View Post
How'd you get the CASIS light to only come on at 6000 RPM? :-)
Hehe, maybe it comes on at redline, or just be lifting off the gas for a split second made it light up
80's programming:
///CASIS Code generated by Porsche, do not modify///
If VACUUM then LIGHT =0
If REVERSE then LIGHT =0
If WOT then LIGHT =0
If 5TH then LIGHT =0
If not WOT and not 5th gear then LIGHT =1
If redline then LIGHT =1
///End CASIS code///
Jason Herriott
Old 10-20-2017, 03:45 PM
Originally Posted by Trakrat View Post
Replace that Fabspeed crap and you'll get even BETTER performance.
Fabspeed is just temporary as the existing non-stock muffler was contacting and heating up the bumper. I'll be doing some type of headers with heat exchangers.
Jason Herriott
Old 10-20-2017, 03:49 PM
Originally Posted by FstTarga View Post
-I’ve removed all the ac system back to front
-911R style tail lights and carbon fiber reflector delete
-lightweight exhaust, b&b headers with custom sport cat equipped x pipe exhaust.
-no engine sound pad, or interior sound deadening under the carpet
-backdated heat
-Tillet carbon fiber bucket seat on drivers side and soon to be sparco seat on passenger for a bit of extra comfort for the passenger
-rennspeed fiberglass duck tail engine lid
-boxster caliper conversion in the front
-hollow torsion bars
-spare tire, tool kit and trunk carpet removed
-battery replaced with oddesy 680
-soon to be RS door panels from appbiz ( box is in my living room)
Pic is a couple months old, before I did my R lights
I love the look! Thanks for the list of weight savings
Jase.
Jason Herriott
Old 10-20-2017, 03:55 PM
3.2 Carrera pulling good?
Here is my 86 for comparison just 2nd gear pull and partial 3rd. Non chipped M&K with cat bypass.
https://youtu.be/Z1FvuQON3yA
Old 10-20-2017, 06:15 PM
^ Very nice brother!
Jason Herriott
Old 10-20-2017, 07:33 PM
