How does the screw cover mount? Is it just glued on? It has an indentation for the horn button, but that's it.
Steve 75 914-6GT clone with a 1995 3.6 DME motor, 915 trans with Martin Bott 916 shift kit, MB911 heat exchangers, boxster brakes, etc... Special thanks to Patrick Motorsports for fixing my 915/916 trans and there associated 3.6 conversion parts. |
Picture of other side of cover
I would think the horn button would hold it in place when the button is snapped into place. (button has tabs that locks it into place when inserted in hub.)
Paul 2011 Cayman S | 1978 911 SC | 1975 914 | 1987 951 1995 993-Sold |1998 C2S-Sold | 2002 M3-Sold Instagram: @rennsport98 |
Always learning something
^^^this
1987 930 Guards Red 2004 Acura NSX Supercharged 2020 Macan S |
Thanks for the help. It's a loose fit in the wheel, it must snap into the hub behind the wheel. I will try it tonight.
I have the same wheel. The beauty ring was always shifting around on my wheel, the horn button tabs weren't strong enough for a very snug fit, so I never ran it. Not sure if it was an idiosyncrasy of my parts, or that's just how they are.
1983 SC Coupe Chiffon White 3.0 rebuilt by me 9.5:1 964 Cams. SSI's. Backdated heat. KEP sports clutch. |
Reiver
A few bits of double sided tape...
De Oppresso Liber Strength and Honor 5th Legion |
I have a cheapo knockoff Porsche crest horn button and it holds that ring in tight on mine.
Matt - 84 Carrera |
My Jwest offset does not have lip that the horn slides into. My only choice is to either remove the offset ring or add a Momo spacer with the lip. For now I just added the external horn ring.
I installed one in a friend's car and the beauty ring was loose, too. I didn't like the loose fit, but he was okay with it.
The fun - '06 Carrera, '79 930, '06 S4 Avant, '16 i8 The mundane - '24 Tesla Model 3, '22 Tesla Model Y, '19 Tacoma |
I ordered a retaining ring for the horn. It was less than $10.00. I will install the beauty ring when it comes in.
My horn button was sandwiched between the steering wheel and the beauty ring.
2003 Targa 996 2009 Cayenne GTS 6MT |
