I would have thought that this thread is done when we posted the combination wrench trick ...
Well .. the combination wrench is just a simpler version of flywheel lock. Rotational forces are still an issue for a 1-time DIY guy R&R'ing his flywheel on the garage floor. A simple 3-4 foot piece of angle iron negates that issue.
If anyone is wondering how the factory did this.
http://forums.pelicanparts.com/uploa...1511296743.jpg |
^^^ P238 works fantastico if you've got access to one. Just used mine the other day! |
this is just me Ivan |
As an example of the washer cut for a flywheel lock that I talked about on post #5.
The bottom cut fits the 1964 911 flywheel (same as the 356 on just the early cars) - this BMW flywheel has a smaller gear notch. Note the pressure plate mount bolts have unbelievable buggered up bolts - none can be removed - so no place to bolt onto the flywheel. ( It looks like the T40 bolt heads were put in with an Allen - pre-stripped. Ended up welding on 13mm nuts to each bolt head to get them out.) http://forums.pelicanparts.com/uploa...1511627190.jpg |
Older thread, but just wanted to throw this picture on there to help get people's creative juices flowing for a solution vs buying the tool.
I didn't have any scrap metal laying around and was also over-thinking the issue. Then I realized I had a chain I use for my engine hoist. http://forums.pelicanparts.com/uploa...1527220636.jpg |
A long punch thru one of the pressure plate bolt holes against one of the case ribs behind the flywheel.
IIRC I put some 10mm socket or something.
http://forums.pelicanparts.com/uploa...1527265132.jpg Flywheel bolt on one end and transmission bolt on the other. |
Thanks for the tips!
Next question... How about when you are torqueing up the pressure plate and can't use one of those holes? |
I haven't usually had as much trouble torqueing the pressure plate. Try holding the torque wrench in different clock positions relative to the flywheel.
Thanks!
I used the Jeff trick as well
