jmz jmz is online now
jmz's Avatar
Options for a shop that can widen a set of fuchs?
Can I get some suggestions for widening a set of 16" fuchs? I would like to have some welded up and widened.
Seems like Weidman may be behind for a while. Any other options?
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud)
'70 914/6 Race Car (Faster and Louder)
'71 73RSR tribute vintage race car 3.0
'68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox
'81 Magenta IROC clone in progress 3.6 varioram/G50
Old 02-12-2021, 09:23 AM
Sent my 15” Fuchs to Weldcraft.
Good work. Widened by 1”
Old 02-12-2021, 10:30 AM
Harpo's Avatar
I want to narrow my fuchs by 2 inches. Yea there in metro Detroit.
Old 02-12-2021, 10:35 AM
(man/dude)
Jonny042's Avatar
+2 for Weldcraft. Note that they can and will only widen on the inside of the wheel.
They did a pair of Euromeisters for me - front 7" to 8".
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 02-12-2021, 11:00 AM
70SWT's Avatar
One more thumbs up for Weldcraft. They created a pair of widebody wheels for me a while back.
2018 911 Carrera coupe
1972 911T targa
Old 02-12-2021, 11:40 AM
When you widen a 7" wheel by an inch how does it fit on the front of a 911? What tire are you running?
I tried the 944 Fuch 8's on the front of my 911 SC and did not like the fit. Fenders rolled and still not enough clearance.
Old 02-12-2021, 12:17 PM
Mr. Merk's Avatar
I have these on a 3.2 Carrera with 225/45r16. You might need a bit more negative camber. I'm running -1.4 right now with my left front rolled and it works fine fairly low.
SWB 912 - G50 Carrera - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS
SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo
Workshop Coordinator at Ehrlich Motorwerks
instagram.com/patrickossenkop
ehrlichmotorwerks.com
Old 02-12-2021, 12:20 PM
That looks great!
I am running -1.9 deg camber so should be fine. My car is a little lower than the blue car, but still looks like it would be ok.
Glad I saw this thread!
Old 02-12-2021, 12:27 PM
Any idea how much clearance on inside?
Old 02-12-2021, 12:30 PM
Mr. Merk's Avatar
That looks great!
Thank you! No idea the inner clearance measurement, but I know there is room to spare. Bill Verburg actually recommends a custom offset of et27 (the 951 8's are et23.3)
I think what makes this work well is the shorter 225/45 tire. I corded my front tires while having fun in Colorado, and had to temporarily run some 225/50 Conti DWS06 to get back to Arkansas. It drove GREAT on the highway, but definitely rubbed when cornering. I think I was at about -1.8 camber at the time.
Old 02-12-2021, 01:39 PM
Jay ++ for weld craft
Ian
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 02-12-2021, 09:08 PM
Harpo's Avatar
I have a pair of 7x16 (951/944) and a set of 8x16 (944/951). The 7's are great fit over my 930 calipers and great fit in the rear but questionable in the front. The 8's wont work anywhere and I'm hoping it will be cheaper to narrow the 8's to 6 as opposed to buying another set of 7's. Still waiting on my quote from James.
Old 02-13-2021, 05:38 AM
Crotchety Old Bastard
RarlyL8's Avatar
I'm looking for a set of 951 8x16 if you are interested in selling.
Old 02-13-2021, 05:59 AM
Science is NOT optional
rbogh901's Avatar
What are they charging?
PCA member since 1993
Old 02-13-2021, 06:44 AM
(man/dude)
Jonny042's Avatar
The widening actually changes the offset to 1/2" greater - so the 23mm offset wheel becomes a 40mm offset wheel. I run a 12mm spacer with longer studs to bring the offset back to stock. I did have to roll the fenders pretty hard and there's some slight rubbing on the inside at full lock. To confuse matters I added offset balljoints, raised the spindles 40mm and run the car pretty low. This is all so I can run a 225 tire on the front to reduce understeer for autocross:
Old 02-13-2021, 06:53 AM
jmz's Avatar
Thinking that may make the offset too deep I think. These will be on my 914/6 GT that has a bit wider flare than standard. Wanting to run 16x10 square.
Old 02-13-2021, 09:37 AM
(man/dude)
Jonny042's Avatar
Wow that's a lot of tire!!! If you start with 16 x 9's it should work but $$$
Old 02-13-2021, 01:55 PM
(man/dude)
Jonny042's Avatar
Found the invoice. It was a few years back, $225.00 per wheel.
Old 02-13-2021, 01:57 PM
RarlyL8's Avatar
Price depends on size and width added/removed. Each job is quoted before being accepted. Just had a set of 20x8 widened which came to $370/wheel.
Old 02-13-2021, 03:34 PM
