thisisgoodnews's Avatar
3.2 ICV connector rubber boot
Went to fix up a damaged wire close to the connector of the ICV valve. Could not de-pin it, so destroyed the connector with cutting pliers and ordered a new one. My connector never had the rubber boot and was always just wound with an electrical tape.
As I am already there, now would be a good opportunity to put on a correct rubber boot. Tried to look up the PET, but could not find it. Thing is, here is needed a 3pin rubber boot for a JPT connector, but the OEM ones are much longer, reaching the brown protection tube. With the available ones, I suspect, they are too short to reach the brown tube, so I would need to add heatshrink, which I want to avoid.
OEM look:
The one type I could find:
Anybody has a hint?
'86 3.2 Carrera
Old 12-20-2023, 09:53 AM
You just need a 2-way Junior Timer rubber boot. See the link here for a 90-degree version:
https://kojaycat.co.uk/epages/950000457.mobile/en_GB/;ClassicView=1?ObjectPath=/Shops/950000457/Products/2w-EV1-Inj-Sup-Boot
If you Google the above, you will have lots of options.
Edit: if the ICV connector is a three-way, the one you show should work. I cannot recall if the ICV is 2 or 3 way...
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc.
'07 Boxter
Old 12-20-2023, 11:12 AM
It's a three way connector. My concern with the one I find, is that due to shorter length, will not reach the brown protective tube.
'86 3.2 Carrera
Old 12-20-2023, 11:30 AM
fallingat120mph's Avatar
Mine is cracked also so be interesting to see what you find out.
Erik
1986 911 Coupe
1986 911 Targa
Old 12-20-2023, 12:55 PM
Check out this place here. Scroll down to reference DPCG19. This may work. This is in French, if you need help buying please ask.
But I'm sure you can find it local too.
Gilles
RoW 88 Carrera coupé
Old 12-21-2023, 12:28 AM
Erik
There are at least 2 variants of the 3-way Bosch JPT connector, went this this one:
1 284 485 064 Bosch Housing
1 280 703 022 Bosch Waterproof Boot
927770-3 TE Terminals
bouth it here: https://www.ebay.com/itm/131119891240
Be sure to buy whole set, because, to my understanding, original terminals are not depinnable. Here is a cut-away view of the original pin and the remnants of almost fully destroyed original plastic connector housing:
I had one of the ICV wire insulation damaged, so I trimmed the wires, put new boot, pins, connected it back. Due to shorter wires, boot had enough length to go over the brown harness sleeve.
'86 3.2 Carrera
Old 01-02-2024, 07:16 AM
