Uneven startup.
My SC engine with original injection system, CSI, will not run even for the first 10 sek., yes it can be hard keeping it running at all. I imagine this is caused by air comming into the injection lines, the one from the distributor to each of the sylinders?
My question, are this simple injectors supplied with a one one valve and if, are they often known to stay stuck open after long time use?
Arild |
no, you don't get air into those lines.....unless you are out of gas or it vapor locks, not likely unless you have a bad check valve, but then the engine has to get hot.
how about a year of the car. I assume an ROW. if it starts and wont keep running then the CSV should be working ok. could be: air leak bad fuel pressure(s) fuel pump not running after start issue with fuel distributor fuel filter screen in fuel tank clogged make sure ignition is good. plugs cap rotor
