Dead SC
Drove my 1980 911 yesterday and had no problem starting. Today everything is dead. Nothing happens when you turn the key, no lights, clock stopped, nothing. Battery is showing fully charged. Is there a main fuse? I have no owners manual and I'm a newbie.
Hi Mark...check your ground connection on battery
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Clean the battery terminals and the chassis ground.
Could be an ignition switch issue as well.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Battery ground and post clean and tight. Can a bad ignition switch kill everything?
Got it! Someone installed a kill switch under the dash that has a key. Key was not all the way turned. Thanks all
Dead battery? Did you leave something like the lights turned on or the glovebox light on? I have had batteries die overnight for no explainable reason!
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
after market crap strikes once again ..
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
