Adjustment screw for headlamp
In the process of disassembling my headlights, one of the adjustment screws and the flexible part of it got its threads stripped. Seized and I couldn't rescue them.
I cannot find these parts anywhere, if someone knows where to source these, I would really appreciate knowing where. Br
Is the section with the push/pull tab the stripped one? I realize that H1 stuff is super rare. Have you tried ebay user soterik ? I’ve seen a pair of his repros and they’re as close to perfect as possible.
If all else fails, can you replace the threaded section with matching threaded stock? Bill |
Thanks for the response, Bill! I need all parts, the flex-bit and the two threaded pins. I will try soterik, hopefully he can help me out.
