Hole lot of questions
66 912. What passes through each of these holes? E-brake, heater cables, and shift rod I pretty much have everything else though?? Thanks
Old 08-14-2025, 12:50 PM
WFBowen's Avatar
Here’s the basic layout (thanks to member jcunning .) This is for a FI car so it shows a return line instead of the single 912 fuel line.
Old 08-15-2025, 11:53 AM
cmpski's Avatar
Go to www.912bbs.org. That is were the 912 folks hang out.
1959 Auratium Green 356A Super w/ Rudge wheels
1970 Irish Green 914-6 w/2.2S
Current -1967 Bahama Yellow 912 POLO 2cam4 #1
Handles like a 912 and goes like a 911
www.reSeeWorks.com
Old 08-15-2025, 02:27 PM
Banned
On a ‘66 912, here’s what typically goes through those:
- Center big hole: Shift rod
- Upper small holes: Usually heater cables or wiring harness grommets
- Lower left/right holes: E-brake cables
- Larger hole on the right: Throttle linkage rod
- Smaller ones around: Often for wiring, clutch cable guide, or misc grommets
Old 08-19-2025, 04:25 PM
cmpski's Avatar
This might help.
It looks like you got this already.
www.reSeeWorks.com
Old 08-21-2025, 12:54 PM
