BIG brakes for the 912?
Hello!
i´m searching for the info for putting big ones to the 912,
(i have 944 turbo brakes in my vw panel - awesome stopping power - i want this also in the 912)
but i havent seen any good topics how and what parts to use...
do you have any good links or knowledge what to use, theres a set opf boxter brakes for sale, and some bigger brakes from porsche, ...do you know any company that sells a good set disks + calipers?
the original engine is out of the car, and something between 66x90 six or a modified 3.0 will be replacing the 1720 cc flat four.
i will be also getting 7x17 wheels so the wheel measurement is not the biggest problem.
thanks for your time. Jyri / http://volkswanker.blogspot.com
Old 05-06-2009, 04:55 AM
C. Clark's Avatar
Try here, they do some interesting projects.
http://www.912bbs.org/index.php
912 Renegades section.
Chas.
356912911
Old 05-06-2009, 09:07 AM
Max Sluiter
Flieger's Avatar
http://www.early911.co.uk/html/calipers.html
These fit inside Fuchs
Old 05-06-2009, 01:37 PM
Hey, that is a good link!!! Thanks! Im still considering also original porsche turbo brakes... :-)
Jyri
Old 05-06-2009, 03:20 PM
but why is it necessary? is the reason the bolt pattern for the calipers? why not use a machined bracket? or are the suspension parts too weak?
Old 05-07-2009, 06:57 AM
what is the bolt pattern for the normal 912 calipers?
and is it same with the 911s / turbo?
Old 05-07-2009, 06:59 AM
jmiemiec's Avatar
Hi, also to consider the weight of the car, as I have once been told by a P mechanic. Anything under 1000kg will do greatly with front M calipers from the T.
Old 05-08-2009, 11:40 AM
Hmmm. I have 944 turbo brakes on my v-dub panelvan, and the stopping power is So great. I would like big powerful brakes especially on a porsche. I just bought a 993 brake set
Old 05-09-2009, 09:44 AM
i bought these for dirt cheap. they are from a rs2 audi, and theres also a setup from a 944 turbo
lets see how they mix. :-)
Old 05-11-2009, 12:29 AM
so far, i´ve started to make a bracket from a wood block, to see what it needs to put these 944 turbo brakes to a bone stock 912. my new 993 brakes are coming hopefully this week, so i will see which ones are easier to adapt.
can i use the emergency brake parts from a 944 in a 912? or should i do a bracket also to the rear?
Old 05-13-2009, 06:26 AM
hmmmm, any suggestion where to get a good master cylinder for this kind of setup?
mine´s a bit sad... :-(
Old 05-15-2009, 05:42 AM
Just removed the whole assembly, and it looks "do-able" ;-) tomorrow i also have the other brake-set to compare... Can't wait...
Old 05-18-2009, 12:25 PM
914 Brake Master Cylinder 91135501202
Old 05-23-2009, 07:34 AM
euro 323's Avatar
whats the results on the comparo?
67 911 widebody 350 5spd,
78 911 sc , 82 323i BMW,
90 Corvette L-98 ,92 CORVETTE LT-1
99 MIATA 10yr sp.edition #4427 of 7500 ,
2001 Lamborghini Diablo kit under construction
Old 05-25-2009, 11:42 PM
The result: we will use the 944 turbo brake parts, the front brackets are ready, but in a zink-treatment, but the rear is a bigger problem. Is there any aveilable bracket for this, or is the best way to take the rear brake assembly off, and send that to the machinist? Seems like the rear disc fit well/easily to its
place. :-) but the caliper fitment is the hard Part. So if someone has a solution, please let me know. Thanks. Picks will come to my blog later on...
Old 07-10-2009, 05:59 AM
Forgot to write that the big red needs total overhaul, so if someone knows, where to get a total rebuild kit, please let me know. :-)
Old 07-10-2009, 06:03 AM
ok, things are going better, got my parts back and the banana shaped adapters...have to take some picks. and grind a bit from one place, + get some new bolts. :-)
but it looks promising...
Old 12-19-2009, 09:37 AM
in one picture you can see the shape of the bracket...
Old 12-19-2009, 09:39 AM
ok, check out my blog, its pretty tight fitment n´est pas?
grinding needed. plus maybe a spacer...
volkswanker
Old 01-10-2010, 08:38 AM
Tags
brakes , porsche 912 , racing , turbo , volkswanker
