Breather Hose
I am currently runnung my car with the breather hose connected to a coke bottle with a little hole in it and the car runs great. When I put the breather hose into its spot on the carb the car runs really badly. I do get a liitle fluid in the bottle (milky) and it smells like gas. Why?
Old 05-18-2002, 06:19 PM
Howdy,
If the breather hose makes excessive fluid and smell like gas, you have severe blow-by. The rings are probably worn and allowing fuel and exhaust to get into the crankcase.
Check your oil for the same smell. Chances are it is also wetted by fuel. A rebuild will take care of this problem.
Regards, JMB
68' 912/5 modified brakes, suspension, limited slip trans, hi-performance engine.
67' 912/5 racecar project
Old 05-20-2002, 09:44 PM
