atlporsche's Avatar
901 tranny lube...
what's everybody using??
I'm going to replace mine. just wanted to know if anything worked better or worse...
I did a search, and there's the swepco lovers and the mobil 1 90W lovers...
so I don't have to look it up...what's capacity?
sjd
Old 11-19-2002, 12:55 PM
Swepco..............
capacity 2.6 qts.
Craig
Old 11-19-2002, 01:03 PM
Green 912's Avatar
Personally I use whatever was in the trans before. I only switch to synthetic after a full rebuild and for track use. The school of thought is that the syncros set in based on the coefficient of friction and there is a good difference between dino and synthetic. Many a mile has been driven on dino and the early tranys were made to work with them.
Old 11-19-2002, 02:17 PM
Morrie's Avatar
Swepco 201.... made a noticable difference over whatever was in there before (Unknown black goo)
Whether or not it was the simple fact it was new stuff or that Swepco has additives in it that help, I can't say.
Morrie
67 912 Coupe
Old 11-20-2002, 03:44 PM
abit off center
cgarr's Avatar
Kendall NS-MP Hypoid 80-90 part # 527-7730 Just like the good ole days
Craig
Old 11-20-2002, 04:29 PM
atlporsche's Avatar
I fear that unknown black goo is in there.
swepco widely available?? I may just add it to the order I need to place with wayne...
sjd
Old 11-21-2002, 05:30 AM
Morrie's Avatar
I got mine through Wayne.... Good price and one "jug" is enuf with a little to spare.
Morrie
67 912 Coupe
Old 11-21-2002, 07:37 AM
sjd,
Swepco seems to be a good tranny oil for our transmission. But I think any name brand hypoid 80-90w gear lube should be okay. I think what is important is to use a good brand and change it on a regular schedule. Black goo running in the tranny can't be good for the tranny.
Since Swepco runs about $40-$50 a gallon, a suggestion that I followed was to change the old tranny oil with a regular brand name oil, run it for 200-300 miles and then change that out replacing with Swepco. Then use Swepco as the regular tranny oil when changing it.
I hope that helps.
Jones Low
69-912
00-Box
Old 11-21-2002, 01:39 PM
