Eduardo Castrejón Elbjorn's Avatar
Send a message via ICQ to Eduardo Castrejón Elbjorn
Question M caliper rebuild kit problem
Hi,
I bought a complete 72 911 front suspension with M calipers (3 " space, iron).
My calipers are this:
I bought to Pelican the rebuild kits but are huge for my caliper pistons:
The caliper kit is:
ATE
901 351 964 11
Front calipr rebuild kit, steel M, 911/912 (1965-75), 914-6
What happened here ?
I really don´t have idea
Please help me
Regards
Old 03-03-2003, 09:41 PM
914 Geek
Hmmm.... Could they be rear 911 brakes? Those have different piston sizes than the fronts. I forget the exact sizes, though!
Ahh, here we go. Mr. Anderson sez: Rears == 38mm dia. pistons. He doesn't say what size the front pistons are, only that the rears ones were smaller than the fronts.
--DD
Old 03-03-2003, 11:58 PM
Andrew9146's Avatar
Eduardo,
I purchased 2 of the front brake caliper rebuild kits from Pelican. When I checked inside the blue boxes, they were different sizes! I sent one back.
I now have two the same. I hope I sent the correct one back, they are still in my garage waiting for that particular project to start.
Andrew
Old 03-04-2003, 03:16 AM
Dave:
Thanks for your answer
Yes, my pistons are 38 mm
Then, Do I have rear m calipers ?
But I don´t have any mechanism for parking or emergency brake, then ?
Andrew, thanks for your answer, I will investigate this.
Regards
Old 03-04-2003, 10:35 AM
914 Geek
The 911 rear brakes used a separate drum brake mechanism. I suspect you have 911 rear brake calipers there. Not certain, though.
--DD
Old 03-04-2003, 04:17 PM
