working on my porsche
I have a 1972 Porsche 914 with a 1.7 I am removing the engine to get some body work and paint done it has 38.000 miles on engine I was wondering what else would you recommend I do while its out and can work on it easily thanks for any input
I’m restoring mine as well, engine out and suspension removed. Check for rust where the clutch tube exits the tunnel.
Check for rust EVERYWHERE.
Jacksonville. Florida https://www.flickr.com/photos/ury914/ |
Control Group
Adjust the valves, clean up the oil cooler
She was the kindest person I ever met |
I would clean, clean, clean. Engine compartment, wheel wells, underside, inside under floor mats. Checking for rust as you go. All before sending off for paint, you may need a little body work first.
1974, 914-6 GT Tribute 2007 Cayman S 1998 993 Carrera S, speed yellow (Yellow Bird) gone but not forgotten. 2017 Golf Sportwagon 4motion Exclusive source for the 914 Umbrella and Service cover |
thank you
Administrator
If you've documented any of the work, post some photos and a few lines. We're running a DIY contest with up to a $1,000 gift card. Link below.
http://forums.pelicanparts.com/off-topic-discussions/1023088-post-your-diy-build-forum-contest.html |
