mike_the_man's Avatar
MPS question
Hi all,
This maybe a silly question, but here it goes: I have heard that to test the diaphragm you can suck or blow into it? Which is it, I assume suck. Then what do you look for? I would imagine that there should be no suction coming from the two little vents in the back, but can you hear if it is leaking? What is the best way to tell if the diaphragm is deffective. Any help would be great!
Thanks,
Mike
74 914 2.0L
78 VW Gti
82 VW Rabbit
Old 05-02-2003, 12:25 PM
Bleyseng's Avatar
Send a message via ICQ to Bleyseng
Take a standard vacuum auto pump and attach the hose to the MPS. Pump the vacuum up to 15hg on the gauge and if the MPS holds the 15hg for say 5 min or so without much leakdown (2-4lbs) then the diaphram is good.
The diaphram could be good but other reasons the MPS leaks are:
1. The case halfs o ring is bad
2. The paper gasket that the diaphram seats to is bad.
3. Someone has adjusted the MPS out too far so the mix screws are leaking. (rare)
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression)
www.914Club.com
My Gallery Page
Old 05-02-2003, 12:40 PM
bowlsby's Avatar
Get trhe pump with a gauge as Geoff says. A suck test is not reliable becasue it does not tell you if it leaks down.
Old 05-02-2003, 01:29 PM
norustscott's Avatar
IT does if you keep your tongue on the end..
Scott
1982 911 SC
1962 sunroof bug
1991 WE Vanagon CARAT WRX conversion
Old 05-02-2003, 02:21 PM
bowlsby's Avatar
The tongue test is not reliable and it is a myth Scott.
I have lost count of how many MPS units sent to me that I have evaluated that were 'known good' where the suck test was used to determine that the MPS was good, and the problem is that it cannot reliably indicate leakdown. It s just plain false. Only a vacuum pump with a guage can tell you what you need to know.
Old 05-02-2003, 02:43 PM
like this
Tom
1972 1.7L resto in progress
1997 blazer
1985 F250 (stump puller)
Old 05-02-2003, 03:37 PM
chrisreale's Avatar
Yup, I "suck tested" two of mine, and they passed. used a vacuum gauge, and both leaked at the diaphram....bummer
1973 914 2.0 PCA Member GGRwww.pelicanparts.com/gallery/chrisreale/
www.914club.com
Old 05-02-2003, 03:41 PM
ok ok ok, MPS and jokes don't mix I see...I guess @ 400 bucks each nothing is funny...
Scott
1982 911 SC
1962 sunroof bug
Old 05-02-2003, 04:37 PM
Bleyseng's Avatar
The problem is unless you can suck a golf ball though a garden hose you can't produce enough vacuum like the pump. The cracks inthe diaphram are small to start and seal themselves at low vacuum. At 15hg they leak like crazy! That's why a leaky MPS will run fine but the idle is goofy and hard to set right. Its amazing to just switch a leaky one for a good one and see the difference in the idle right away.
Geoff
www.914Club.com
My Gallery Page
Old 05-02-2003, 05:31 PM
Just another thought
I used the "suck" test and my MPS seemed OK. I could not get the engine to idle properly at all. I borrowed a vac. guage and it would not even hold 5 hg. My unit was leaking at two places: around the plastic that goes into the unit (the wires plug in here), and by the adjustment screw. Yes, I had been fooling with the adjustment trying to get it to idle. I used a little sealant around the plastic and resealed the adjustment screw and all is well. Now it will hold 15 hg for more than the required time.
Good luck
Pritchard
Old 05-02-2003, 06:33 PM
914 Geek
Dude, where are you getting MPSes for $400 each? Let me know, and we can make a mint!!
I think list is now in the 600s... AAAAAGHHHH!!!!!!
--DD
Old 05-02-2003, 09:58 PM
jamcleod's Avatar
Send a message via AIM to jamcleod
guess i'll have to pull out those 6 i've been stock-piling in my parts bin!
73 914 restoration project
73 914 2.0 CIS #80
74 914 1.8L L-jet
83 911SC
Old 05-03-2003, 07:36 AM
I bought one from the TheBusDepot.com two years ago for $279.00...
Scott
1982 911 SC
1962 sunroof bug
Old 05-03-2003, 08:54 AM
