Oil leaking 914
I have a 73 914 2.0 that is leaking oil when running. The oil is running down the oil filter. I changed the filter but that wasn't it. I thought it might be the oil cooler but after removing the engine it doesn't appear to be wet. If the oil pressure relief valve has a problem will it leak oil? Thank you.
Tony |
What have your pressures been like? Look at the galley plugs first.
Check the oil pressure sender in the engine bay beside the distributor.
If its leaking it will trickle down over the filter and oil cooler. |
