cooling tin ware for 2.0 engine
Need to buy the complete cooling tin ware for 2.0 Porsche 914 and I mean complete
Old 12-23-2019, 10:29 PM
dr914 ***********
all of the tin is VIRTUALLY the same for all of the 1.7 1.8 and 2.0 EXCEPT for the cylinder covers, and if you cut the correct spark plug holes you can use the 1.7 or 1.8 for the 2.0 It is commonly available used out there and some suppliers still have some new old stock
Old 12-27-2019, 10:18 AM
914 Geek
The difference in the cylinder covers is the position of the spark plug holes. Those can be moved if you can weld the thin sheet metal.
The bottom-most engine tin pieces, the ones that attach to the heat exchanger and the outside of the sump, are different through the years as well. The left-side one changed in 73 to make room for the side-shifter's rear shift rod, and both changed in 75 to attach to the fairly different 75-76 exhaust.
--DD
Old 12-27-2019, 04:07 PM
