While I'm in there
I plan on rebuilding my pedal cluster with new bushings etc. "While I'm in there", I'm thinking of replacing my clutch and throttle cables. The current cables have been in 15 years.
Cheers, Elliot
Elliot Cannon Paso Robles, Ca. "Nationalism is an infantile disease, the measles of mankind". - Albert Einstein Maintain thy airspeed, lest the ground arise and smite thee. |
914 Geek
Sounds like a plan.
Double check the roll pin on the pedal cluster; at one point the pins supplied with bushing kits were not that strong and would fail shortly after installation. The pin should be a spiral, not just 3/4 of a circle when viewed from the end. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Thanks Dave. Does the Pelican Parts bushing kit contain the proper roll pin?
914 Geek
I don't know. I think the pin has been upgraded now, but I'm not actually sure.
--DD
