While I'm in there
I plan on rebuilding my pedal cluster with new bushings etc. "While I'm in there", I'm thinking of replacing my clutch and throttle cables. The current cables have been in 15 years.
Cheers, Elliot |
Sounds like a plan.
Double check the roll pin on the pedal cluster; at one point the pins supplied with bushing kits were not that strong and would fail shortly after installation. The pin should be a spiral, not just 3/4 of a circle when viewed from the end. --DD |
Thanks Dave. Does the Pelican Parts bushing kit contain the proper roll pin?
I don't know. I think the pin has been upgraded now, but I'm not actually sure.
--DD |
| All times are GMT -8. The time now is 10:43 AM. |
