While I'm in there
I plan on rebuilding my pedal cluster with new bushings etc. "While I'm in there", I'm thinking of replacing my clutch and throttle cables. The current cables have been in 15 years.
Cheers, Elliot
Elliot Cannon
Paso Robles, Ca.
"Nationalism is an infantile disease, the measles of mankind". - Albert Einstein
Maintain thy airspeed, lest the ground arise and smite thee.
Old 01-28-2020, 02:38 PM
914 Geek
Sounds like a plan.
Double check the roll pin on the pedal cluster; at one point the pins supplied with bushing kits were not that strong and would fail shortly after installation. The pin should be a spiral, not just 3/4 of a circle when viewed from the end.
--DD
Old 01-28-2020, 09:42 PM
Thanks Dave. Does the Pelican Parts bushing kit contain the proper roll pin?
Elliot Cannon
Paso Robles, Ca.
Old 01-29-2020, 10:56 PM
914 Geek
I don't know. I think the pin has been upgraded now, but I'm not actually sure.
--DD
Old 01-30-2020, 11:51 PM
