-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=7)
-   -   Backfire into intake (http://forums.pelicanparts.com/showthread.php?t=1057814)
gjames 04-13-2020 07:34 AM
My 914 had not run for 3 years. I soaked the cylinders in WD40 for a couple days before starting. I discovered heavy rust in the fuel tank so I replaced:
Tank, hoses and pump.
Injectors and engine bay fuel lines
And Flushed the long fuel lines until they ran clean
The engine started but there was no power, poor idle
I Replaced:
Points/plugs/condenser/coil.
Reset timing and idle (The dwell is no high side- 58)
Power is back and idle is good.
The Problem:
When I give it gas, it will back fire into the throttle body. It seems to happen a 2k - 3k rpm range. It's doesn't happen every time.
Ideas?
gjames 04-13-2020 09:58 AM
The motor is 2l with FI.
jess p 04-13-2020 01:05 PM
The culprit is certainly attributable to the vehicle having sat for soo long. Sea foam is some amazing stuff. Add a pint to the engine oil as well as a pint into the fuel tank. That should clean up some sticking injectors, clear out any gunk on the valve stems and lifters. It might take a little time after running the car but it will clear up.
