correct tire pressure
what is the popular consensus on tire pressure (lbs) for "normal" driving on 195/65/15 tires on the street?
In the shop at Pelican
I used to always run around 30 PSI in each tire. However this is something that varies from tire to tire.
914 Geek
Stock spec is 26 PSI front, 29 PSI rear.
I run 32 PSI all around, or sometimes pump up to 36 PSI for autoX on street tires. It definitely makes the ride firmer! 30 seems to be a good compromise between the response of the car and still being able to keep your kidneys. ![]() --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Dave, what size tire are you running at AX?
bruce
Sit'n here Hav'n a beer. Punkin's gone (sniff) Gotta mow the Lawn... |
And also, do you think it matters if it is a 50 or 60 series for AX?
bruce
914 Geek
For autoX, the shorter the better. I have run 195/50-15. Short-short-short sidewalls, which is good for gearing and handling and responsiveness, and makes for kind of a sucky daily driver. High freeway RPMs and a harsh ride...
I'll probably go 205/50-15 when I get separate race tires; that is the "default" size for 914s in PCA Zone 7 at the moment. --DD
I'm already there with the 205's. Got a good deal on Nittos and they seem to be fairly sticky. With the new motor mounts in I'll be ready for the May 4th AX. Now I just need to get that Orange helmet!!! bruce
