-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=7)
-   -   way to check clutch cable condition ??? (http://forums.pelicanparts.com/showthread.php?t=1063771)
brcacti 06-10-2020 11:51 AM
I still have the car up to get under it. Do people ever check the condition of the clutch cable? I think you can take off the cover where it makes the bend, is it easy to tell or hard to tell if it is worn that way. also it would be great if we could have an upgraded cable MUCH THICKER to install.
Dave at Pelican Parts 06-11-2020 10:12 AM
There isn't a cover on there that I know of. To physically inspect the cable, you need to unhook it from the transmission end, then unbolt the pulley. Once the pulley is unbolted from its housing, you can look at the cable where it bends to go around it. After you're done, you put it back together and adjust the clutch again.
A thicker cable would have trouble going through the guide tubes in the center tunnel. It would also be tougher for it to bend around the pulley. The stock cables don't have issues often enough to make that worthwhile in my experience, unless there is some underlying problem. (E.g., if you're dragging it through the mud regularly, or if the clutch tube in the center tunnel is failing, or if the ground strap is missing so the engine/trans grounds through the clutch cable.)
I know people who have adapted the "pull clutch" setup from the 70-71 911 so that the clutch arm action worked the other way around, meaning no pulley was needed. But a much shorter cable was required at that point. And the necessary pieces aren't exactly common or cheap. There have also been hydraulic clutches installed, but usually as part of a complete drivetrain swap.
To me, it's not a big enough problem to make the solutions worthwhile.
--DD
John Rogers 06-14-2020 04:56 PM
In my vintage racing days with the 914-6 the clutch would disengage at 50% pedal travel. Of course it would engage at 50% also and I got so I could feel what the clutch was doing. It could also mean a clutch disc was wearing out so in any case it was on the jack stands to check things out. A rule of thumb was to always carry spare cables and the necessary wrenches to replace them. We had replaced a clutch cable in an hour at PIR in Phoenix one year so it can be done as the factory designed it to be.
