Heater Lever Indicator Light
Does the Indicator light require a ground wire from the backside of the indicator?
Mine has 1 wire connected to the light but I do not see a ground wire on the other side of the bulb? |
914 Geek
Yes, it does require a ground. On my car, which had a center console, the ground pin connects to a short brown wire that has a ring terminal that goes over one of the mounting screws for the light base.
--DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
