-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=7)
-   -   Tachometer pegging at on and running (http://forums.pelicanparts.com/showthread.php?t=1094703)
surfdogskier 05-31-2021 08:31 AM
Hey guys, ever since I owned this car, the tach pegs out when I turn the key to on, starting and running the car. When I turn if off, she goes back to zero. I have an old 911 gauge that does the same thing when it comes on so I thought maybe it is the wiring.
However, I hooked up a new VDO gauge from another car and it works great. Does all the things a tach should do. So the issue is in the tach.
Any diy guides on taking about the tachs and finding the issues to look for. It can't be that hard. I pretty good a soldering and replacing components. Thought I would try fixing myself before trying to send it off.
Thanks,
Jason
surfdogskier 05-31-2021 07:05 PM
I was able to get into the tach pretty easily. There are about 12-15 resistors that need to be checked. Odds are, it is one of them. I figure it has to do with the hot wire so I will trace those first and go from there.
