-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=7)
-   -   914 Rear window lower seal (http://forums.pelicanparts.com/showthread.php?t=1116297)
Michael Preiss 04-05-2022 03:22 PM
Anybody know how to replace the rubber seal at the bottom of the rear window ? Mine is badly worn .
tonythetarga 04-06-2022 03:31 AM
It is attached to the engine lid I believe. Pop that open, pull it off and put on the new one.
New rubber is readily available.
If you’re talking about the window seal, different story. You’ll need to remove the seats and firewall interior bits that cover the firewall and cut away the seal between the glass and firewall with a razor. Clean the surfaces and put in a new rubberized mastic sealing strip, cut it to size, then reinstall the rear window.
Michael Preiss 04-06-2022 08:33 AM
It is the lower window seal .
Dave at Pelican Parts 04-06-2022 11:50 AM
The lower window seal is, AFAIK, pressed into a channel on the firewall. If it is in good shape, you can probably pull it upward and out of the channel--but if it was in good shape, you probably wouldn't be replacing it...
I have not done this myself, but I believe the process is something like:
- Pull the old seal out of the channel
- Curse while discovering how much shredded seal is stuck in the channel (I suggest fake German swear words!)
- Clean all of the leftover crap out of the channel, accompanied by more cursing
- Push the lower part of the new seal into the channel
--DD
930cabman 04-09-2022 01:41 PM
--DD
Is it acceptable to use Italian cursing? They are almost neighbors ....
Dave at Pelican Parts 04-09-2022 01:54 PM
Well, if you put enough "oomph" into it, and the words are made-up fake-Italian, it should work almost as well. ;)
--DD
Cairo94507 04-16-2022 05:06 PM
Use some glycerin or other lubricant to get that rubber seal to slip into the track. Sometimes just windex on the seal will work. You just need some type of lubricant so it goes into the track easier.
Tobra 05-10-2022 05:25 PM
dish soap works in a pinch
WizPorsche944 05-17-2022 10:31 AM
Good info I need to do mine too. Thanks !
