-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=7)
-   -   914 steering (http://forums.pelicanparts.com/showthread.php?t=1146520)
maurice povey 09-19-2023 09:14 AM
914 steering
Hi Is the steering on the 914-6 heavier than on the four cylinder cars?
mepstein 09-19-2023 09:16 AM
Shouldn’t be. It’s almost identical. Check alignment, tire pressure, etc.
dr914 09-19-2023 12:38 PM
no only with flares and wider wheels and tires does the steering feel heavier
maurice povey 09-20-2023 09:47 AM
914 steering
ok thanks for replies, i'll get the alignment checked, Again!!
930cabman 09-21-2023 02:35 PM
What size tires are you running? pressure?
maurice povey 09-21-2023 03:40 PM
914 steering
Hi I'm running with 15"x6" Fuchs wheels fitted with 195/60 Falkens and Tyre pressures 26psi front 29psi rear and no bodywork mods.
Billthebuilder 09-23-2023 07:12 PM
Stock steering wheel or the smaller momo 350 mm type ? The smaller wheel is harder to turn
dr914 09-28-2023 12:35 PM
and if the front end is lowered!
Emo993 10-01-2023 06:49 AM
I would add a few pounds fo tire pressure all around. Mark
Customdirector 11-15-2023 02:02 AM
From what I've heard, the steering on the 914-6 is generally considered to be a bit heavier compared to the four-cylinder models. The 914-6 had a larger and heavier engine, which could contribute to the difference in steering feel. However, it's always best to test drive both models if possible to get a better sense of the steering differences
