master cylinder supply lines
I'm replacing a master cylinder. Are the supply lines coming in the top just pressed (without fasteners) into the rubber fittings on the master cylinder? Is there a good tool or technique for removing/installing new ones from underneath?
I just can't figure out how to get a grip on 'em. Thanks a lot. --Case... |
the have a flair on the end
scott thacher 75 914 with 2.5 l 98 suby engine on the road |
Thanks, Scott. I got them out. They went back into the new ones easier than they came out of the old. Now I'm bummed because I stripped the fitting on one of the lines putting it back on the master cylinder. Argh!
--Case...
'75 1.8L L-jet 914 |
