1.8 Air Box Adjustment
I realize that to get things perfect, I will need an exahust analyzer but I was wondering if there is a way to ball park the mixture adjustment on the air flow meter. I have a stock 1974 1.8 Ljet.
When I turn the screw clockwise, does this richen or lean the mixture? Unfortunately, I have messed things up thinking that the airbox screw was the idle screw. I have learned a lot since then but I was hoping that someone could give me some tips. Currently, my mixture screw is exactly 4 full turns backed off from fully screwed in - but, I have no idea is this is even close. Any advice would be great - Thanks! |
914 Geek
Screwing that screw in closes the passage that lets air go in without getting measured by the air flow meter. That means less un-metered air is going in, therefore the mixture gets richer.
I don't know that there is a baseline such as "X turns out and it's pretty much right on." I'm not sure how you'd set it without a gas tester of some kind. Maybe set it for "best idle"? --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
