Windshield Wiper - Issues
Hi,
When I bought my car a couple of years ago, the winshield wipers would only work on hi & would not park (I just shut off when they hit the right spot). I attempted to figure out the problem & discovered that the linkage has a few missing screws & I assumed that everything would correct itself as soon as I got everything tightened up. I just picked up a working motor & linkage from a '75 & after I installed it, all of the problems are still there (except now they only work on low) Before I replace my steering column wiper switch, I was wondering if it could be anything else - like relays or something else. Any advice would be greatly appreciated. Thanks, in advance, Vern |
Yes, I think you will have to replace the steering column switch.
Phil |
