-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=7)
-   -   Pedals Squeek Even After a Pedal Rebuild (http://forums.pelicanparts.com/showthread.php?t=115982)
Tidybuoy 06-22-2003 03:53 PM
Help!
I have rebuilt the pedal cluster using all brass bushings. I used white lythiam grease on all of the bushings. I installed a new clutch rod since mine had significant wear at the cable hook up area.
Everything was smooth and quiet but suddenly started squeaking.
This is the second time I have taken the pedals apart & greased them - what am I doing wrong?
kellzey 06-22-2003 06:29 PM
I thought the bronze bushings were supposed to be self-lubricating...
M. Hendrix 06-22-2003 09:56 PM
I know I am!
M
ken180 06-23-2003 08:31 AM
If it is the clutch pedal that is making the noise - check the pully wheel on the transmission, when it makes noise it sounds like it coming from the front.
Ken
Dave at Pelican Parts 06-23-2003 09:35 AM
Check all the moving bits. That includes the clevis where it pokes through the clutch arm, the pivot for the brake pushrod, and the pivot and ball-and-socket joints on the throttle bellcrank.
Check to make sure the pedal cluster is securely held down. Sometimes the weld-nuts break, or some of us forget to put all the bolts back in.... (Nope, never happened to me! Honest!! :rolleyes: ) Sometimes the floor pan in that area gets weak from rust.
--DD
elwood-914 06-23-2003 05:51 PM
The bronze bushings are self lubricating. A machinist friend of mine told me that when machining, oil comes out and the parts get difficult to keep secured.SmileWavy
