CIS TURBO intake size (meter/fuel distributor to turbo)
I wondered in this pic http://www.pelicanparts.com/motorcity/davedarling/ecr_01/turbo1_7.jpg what size diameter it is? I'm running around a 2.5" at 2 feet of run. Should this be fine or go to a 2 inch diameter? Would throttle responce be better with a smaller intake? How about these pix? http://www.pelicanparts.com/motorcity/davedarling/ecr_01/Friday_AM.html
What size is that and about how long? |
Panel, the first pic is of my set up. I am using 2.25-in O.D. tubing for my intake track. Before I added the turbo, the total length was approx 2-ft. After I added the turbo, the length is more than double. The throttle response never changed. The length increase of the intake track did not seem to make a difference on mine.
To answer your question, the 2-in tube would give you a stronger signal and quicker response, but less total air volume. The size and shape of your airflow sensor plate will have a large affect on throttle resonse and fuel delivery. What car/engine size was your airflow sensor originally from? My thoughts are that 2 to 2.25-in diameter tubing works well with CIS. Good Luck, Ed |
Re: CIS TURBO intake size (meter/fuel distributor to turbo)
panel - Given the short run on your setup I don't think diameter will be an issue. Do you have some pictures of your project?http://www.pelicanparts.com/support/smileys/clap.gif |
Re: Re: CIS TURBO intake size (meter/fuel distributor to turbo)
| All times are GMT -8. The time now is 11:07 AM. |
