Temp gauge
Hi all,
I'm planning on getting a Temp gauge for my 914, and I see that Pelican lists one. Does any body know if it's the one with or without the numbers on it? The part # is B-641-118-20. Thanks, |
If it's the small VDO ("cockpit" series) you're referring to, it does have numbers. 0-300F, works well.
Note that you need the adapter ring if you want it to fit into the factory center console. These new gauges are slightly smaller than stock. |
I just added mine a couple of weeks ago. Works great, I don't have a center console and don't want one, so I haven't figured out the optimum mounting method yet.
Next is pressure. |
I believe that the part number you list is for the stock gauge, the one with no numbers that fits correctly into the center console. If you don't have a center console, or if you can live with a gauge that looks slightly different than the others there, get the non-stock VDO gauge with the numbers. You'll need a sender that matches the gauge.
--DD |
| All times are GMT -8. The time now is 03:00 AM. |
