p914's Avatar
Question Clutch pedal difficulty
Occasionally my clutch pedal feels like it is rubbing against something when I press it down. Almost feels like it is rubbing against a cable. Sometimes it makes it difficult to press down. Any ideas? It's not a consistent thing.
TIA
Old 08-27-2003, 04:56 PM
SGB SGB is offline
SGB's Avatar
Check the cable pully?
I know the pully that the cable goes around on the transaxle gets gummed up and doesn't turn well. Thats where my cable always breaks. I've never caught it before it broke, but it seems like it should do exactly what you described when it is hanging up.
-Scott
My gallery page
Old 08-27-2003, 07:37 PM
p914's Avatar
Thanks, I'll check that out and get back to you..
Old 08-28-2003, 09:56 AM
cary's Avatar
Another thing. Take a look at the pedal board under the carpet. I could be delaminating and hanging up on the plywood.
Just a thought.
Mine was doing that. Someone had bent the clutch pedal.
Cary
77 Carrera RS w/3.2 #59
73 914S 2.0 AG
73 914 1.7 Driver ( daily driver, under complete rustoration )
74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor
Old 08-28-2003, 01:37 PM
John Rogers's Avatar
If you have a teflon lined cable, the teflon can melt and grab the inner cable and then soft of fall apart and you will get a really great rubbing feel. I had this happen to the race car and I could feel it in the pedal very much. If you check the pivot wheel and it is soft or deforming then I'd recommend getting one of Patrick's racing ones that can handle 500 degree heat and not deform. Good luck
Old 08-28-2003, 02:31 PM
p914's Avatar
I finally got to this little problem when I got to fixing the speedo cable. I lubed the pulley and also repositioned the floor board a little and there is currently no rub. I'll see how long it lasts. Thanks for all the tips. Now I have a better idea of things to check out regarding that issue.
Old 09-02-2003, 05:59 PM
