ruddyboys's Avatar
CV joint spacers
Putting the drive shafts back onto the transmission and I noticed I only have one spacer per side for the CV joint. When I see the CV joint kits they come with three, Do I really need the other two, if so were can I just buy them?
74 LE "Bumblebee"
03 Jetta Wagon
Old 12-10-2003, 07:19 PM
jamcleod's Avatar
Send a message via AIM to jamcleod
hmmm, spacer? do you mean CV gasket? not familiar with any spacer but am familiar with the gasket.
73 914 restoration project
73 914 2.0 CIS #80
74 914 1.8L L-jet
83 911SC
Old 12-11-2003, 06:10 AM
ruddyboys's Avatar
These are the spacers or washers I was talking about.
74 LE "Bumblebee"
03 Jetta Wagon
Old 12-11-2003, 08:24 AM
914 Geek
Those are more "lock plates" than spacers. I think they are available separately, but it may take a bit of digging to get the part number for the individual parts. Try 888-280-7799; Jason and John are both 914 guys.
--DD
Old 12-11-2003, 08:30 AM
ruddyboys's Avatar
If they are just lock plates and I have one on each side do I really need the other two?
74 LE "Bumblebee"
03 Jetta Wagon
Old 12-11-2003, 09:50 AM
You should use three of the plates on the outside of each CV joint. One plate goes under the heads of each pair of bolts. You'll notice that the bolt holes in the plates line up with the bolt holes in the CV joints. You only need one on each side if you only want two bolts to keep from backing out of each CV joint. If you want all six bolts to stay in the CV joint, probably a good idea given the application, install all three on each side.
'73 2.0 -- Yellow
Old 12-11-2003, 10:07 AM
Member w/ Title Problems
Jason Porter's Avatar
Part # is 90133219100, and I'll hook you up for $2.00 a piece. How many do you want? Just call me. Jason at Pelican Parts - 888-280-7799 ext 238. Peace
2023 Ford F-150 Platinum 5.0 Coyote FX4
2019 Toyota Sienna XLE AWD
Metal Building Erector, Recovering Porsche Guy
Old 12-11-2003, 10:35 AM
914 Geek
Note that the stock 914 CV joint only has four bolts, and two roll pins. Only two lock plates are needed per joint.
--DD
Old 12-11-2003, 12:37 PM
The CV joint kit in the picture is for a VW. The boot has 6 holes and six bolts. The cv joint will work, but as stated there are only 4 bolts, 2 roll pins and 2 lock plates on a 914. I believe you have to drill out the holes a little larger for the roll pins.
Old 12-12-2003, 06:52 AM
