-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=7)
-   -   Missing rear caliper part (http://forums.pelicanparts.com/showthread.php?t=125793)
914GT 09-02-2003 06:20 PM
I could use some suggestions on what to do with my rear calipers. While rebuilding them I noticed the adjustment screw gear (the little gear adjusted from the rear of the caliper) is missing on one caliper. Someone apparently lost it during a past rebuild. Does anybody know of something I can substitute for this part, or can I adjust it by turning the piston gear teeth with a small screwdriver? That's how I got it apart, but I'm afraid without the gear the pad adjustment will not stay fixed. Thanks for any suggestions...
Dave at Pelican Parts 09-03-2003 09:02 AM
The adjuster simply slides out. You can use the one you have and switch it from caliper to caliper. I don't think they're available separately, so you may have to find yourself a used or rebuilt (or whatever) caliper to raid for that part....
Or maybe you can make one from a gear and a big set-screw?
--DD
914GT 09-03-2003 07:05 PM
Thanks Dave. Moving it from one side to the other should work. Maybe I'll run across a cheap rear caliper to scavenge the part someday (better yet - maybe 911 brakes all the way around).
74914 09-03-2003 08:49 PM
*********** supposedly has them. er..I did just place an order w/pelican
sean_V8_914 09-04-2003 12:07 AM
I bought some from Auto atlanta for I think $5 ea. arrived in 6 days
good luck. Ive been told I got lucky
914GT 09-04-2003 08:36 AM
You must have gotton lucky - they're listed for $25 now. Actually two mistakes were made - charged you only $5 AND they shipped it in a timely manner. Someone must have gotton fired for that screw-up. I can get a complete rear caliper off eBay for $20.
sean_V8_914 09-04-2003 10:20 AM
I sold a set of rebuilt and painted rears on ebay for $200. Go for it
