Spotweld drill bit
I am going to do a full floorpan replacement and need to know what size spotweld drill bit I need.
I did some research here and I think Blair bit is the way to go - just need to know what size I need. TIA - Mike
Mike Moorman Durango, CO mike@prosalesreps.com |
You are probably going to go thru more than one bit. You could order several small bits of the same size from a quality supplier like McMaster
Carr and some just a little bigger than the weld itself (which will vary in size). Drill thru the center of the weld as a pilot and then start the bigger bit. Once thru the first body part, it should separate looking much like you used a spot weld bit. Try to buy the larger bit with a flatter point profile; some are really too steep and will go thru before the parts separate. As i understand it, the spot weld bits are spendy. You can buy alot of common bits for the same $. You'll need 'em. |
I would not bother with that method.
Just sawsall the floor near the welds and remove the centers in 4 sections. Then grind the welds off from the bottom. This method was quicker for me and it left nice clean metal behind without the swiss-cheese look of the spot weld bits. The other trick I did was to brace the new floor with a wet 4x4 piece of wood on a floor jack. It kept the floor flush to the car well. When I was done it was really really wierd being in a 914 without the oil-can popping sounds of the floor ![]() -Rich Last edited by Rich Hilgersom; 09-18-2003 at 11:37 AM.. |
Rich, that sound like a plan.
