throtle body
I need a new or used throtle body know anyone who has one....its for a 1974,914 1.8.
Did you try Automobile Atlanta? Their URL is http://www.***********.com/.
Author of "101 Projects"
Oh come on now... I promised myself when I put this BBS up that I wouldn't censor anything on the board, but isn't it a little strange to recommend Automobile Atlanta on our BBS when we have plenty of these in stock?
Let's try to keep Pelican Parts in business instead... -Wayne |
Having had to deal with George and his team in Atlanta over the past six years, I would suggest Pelican Parts. George knows alot about Porsches, but when you are on a time and financial budget, try these guys!
If the problem with the throttle body is related to a worn shaft bushing, I saw something that may help. A friend has a device made for rebushing GM carbs (which apparently use the same shaft diameter as the 2.0 litre type 4). The device reams out the existing hole to fit a replacement bushing. The new bushing is simply pressed in. I'll let you know if it works after I try it. (keep those throttle bodies in stock Wayne, I may need one yet).
