Lots of smoke
I was driving when a very disturbing exaust smell filled the cabin of my car. when I reached a stop sign the cabin then fill with white smoke as well did the out side of the car. The smoke was so bad then when I started to drive I looked out the rear window I couldn't see anything through the smoke.
When I got home I put my car on jack stands to see that I had no hose from the heater box to the cabin. on the drivers side. I started my car and noticed that all of the smoke was coming from a plate that was that I will post a picture of, but intill then, the plate is right next to the the drivers side of the oil pan. All I can think of is an oil pan gasket leak. Any ideas? Thanks Adam
1974 914 1.8 Sold... 1984 944 my baby...more of a pain in the @$$ than takin' it with a cucumber, but I still love it. THE CAR YOU PERVS!!!!!!!!!!!! 1990 Nissan 240sx fastback aka Japanese 944 |
oil dripped onto the heat exchangers and blew it into the cabin. any holes in your HE's? i think you're referring to the "taco plate". check oil level, torque down taco plate. keep an eye on it.
73 914 restoration project 73 914 2.0 CIS #80 74 914 1.8L L-jet 83 911SC |
like the second day I got my car I had oil drip onto the heat exchanger.... boy it was a big cloud, but after that it hasn't ever smoked. It didn't blow into the cabin though
Black 72 1.7 914 http://www.pelicanparts.com/gallery/Biggy72/ WSU Formula SAE Drivetrain team leader/ Suspension team http://www.mme.wsu.edu/~sae/ |
914 Geek
Is the metal plate the one that bolts onto the bottom of the heat exchangers and the side of the crankcase? If so, there's a decent chance that your thermostat cable pulley has fallen off. The hole that the pulley bolt goes into actually goes all the way through into the sump, and when you go around right turns it will leak oil out.
--DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
I did notice a cable that was attached to a pulley at one end and nothing on the other end, and thought that didn't look kosher. My car is going to the shop tomorrow and the mechanic is gonna let me use his lift to fix my car.
How do I reattach the cable?
Read the last post here: http://www.shoptalkforums.com/viewtopic.php?t=46355&highlight=bellows
That doesn't answer your question, I know. But this will help you understand the bellows and what it does should you go fooling with it. |
Deffinatly sounds like an oil leak on the HE's. I drove a 74 1.8 that had a pushrod tube leak on the HE's. It smoked into the cabin, and when you shut it off, it smoked out of the engine compartment.
Eric |
I have H/E but I dont have the plastic aluminum things connection the heater tin to the body.. I masked off the body, Hey its summer, I dont need it! I might try it with no heat in the winter as well, to see if I can stand it.. If I can, then Hello headers!!
my cheap fix, till you fix it right.. (its one of those, just to get it back on the road things)
"It'll fit?" See my V8 thread Pics of my car Hear it with Magnaflow mufflers and shorty headers Or just hear it with open headers ![]() Hear it current, No ugly tips. louder Incar ax vid. 4-2-05 7-16-05 SCCA auto x Stockton. <---------New! |
k smoke problem fixed, now I need the bolt that connect the theromostat pulley cable to the oil sump.
Any help with that one? Thanks Adam
914 Geek
You mean you need the thermostat? The accordion-bellows kinda thing, with a bracket on it, that bolts to the side of the sump?
--DD
No, I need what ever the cable connects to
Banned
The cable runs from the flap down thru a Grommet in the sheet metal to a round wheel then turns and runs over to the thermostat a bellows like object that is held in place by a square braket. The cable attaches to the thermostat with a nut about 1.5 inches long. I checked last week all of these parts are avaiable Except the Bracket. Otto or Conemac Should have those.Steve
