Help--cyl. 3 & 4 not firing
I have a stock '74 914 2.0L.
Recently I had the heads rebuilt. Afterwards, the car ran very well. Learning as I go, I learned that I needed to set the end play. So I removed the transmission, flywheel, etc. and set the end play. Reversed the steps and started up the engine. To my shock and horror, cyls. #3 & #4 were not firing. I checked for compression, good. I checked for spark, good. It was getting late so I haven't checked for fuel through the injectors yet or signals to the injectors. That's for this PM. I haven't disturbed the timing that I know of. It is still close enough for the other two to fire.
If you have any thoughts on what may be happenning, let me know.
Pritchard
Old 12-16-1999, 05:17 AM
RETIRED
Joe Bob's Avatar
Triger points in the bottom of your dizzy...if you are running FI...
Old 12-16-1999, 07:41 AM
I thought about that. But, correct me if I'm wrong, they fire in pairs (1&4, 2&3). So if I'm having problems with cyls. 3 & 4, I'm thinking that it wouldn't be the trigger points.
During lunch today I remembered that I banged the grounding connections near the air distributor several times while removing the nut on the starter/bell housing bolt. If I knocked on of the connectors loose, could this be the problem?
Keep your ideas coming please!
Pritchard
Old 12-16-1999, 09:59 AM
Hey Pritchard it sounds like you are tracking by checking those grounds. The F.I. system won't function properly unless those grounds are intact. Keep us informed. Thanks, Ian
Old 12-16-1999, 08:08 PM
914 Geek
Yup! On my D-jet wiring harness (74 2.0), there are three ground plugs. Each has two wires going to it. The wires are:
Ground for the ECU
Ground for the throttle switch
4 * ground for the injector
In other words, it is likely that one of the plugs has come off.
--DD
Old 12-16-1999, 11:12 PM
Bingo!!
It was the grounding plugs at the air distributor. Whew! Finally something easy to fix! Ha! Ha!
Thanks guys!
Pritchard
Old 12-17-1999, 05:00 AM
