ruddyboys's Avatar
sefetybelts
My sefety belts are sticking. They havent been used in about 8 years
. They seem to stick at the part were the pass thru at your sholder,
and are very slow to retract into the retracter part. What is the
best way to clean the the retractor and belt.
74 LE "Bumblebee"
03 Jetta Wagon
Old 10-12-2003, 09:05 AM
Biggy72's Avatar
I just pulled mine all the way out, shot some wd40 on around either end of the rod that the belts roll back onto, and then pulled it in and out a bunch of times to get the stuff to loosen up. The more you use them the better they'll get.
Black 72 1.7 914
http://www.pelicanparts.com/gallery/Biggy72/
WSU Formula SAE
Drivetrain team leader/ Suspension team
http://www.mme.wsu.edu/~sae/
Old 10-12-2003, 12:19 PM
914 Geek
You can use a large office-supply "binder clip" to hold the belts out, then wash them with mild detergent and water. Air dry.
I would use an actual oil rather than WD-40 when trying to lubricate the mechanism. Light 3-in-1 oil or something similar, perhaps.
Don't open up the sides of the retractor mechanism. It would allow you to clean and lube things better, but one side has a spring in it under a lot of pressure. And the springs have sharp edges. (Got the scars to prove it too!) And I don't remember which side has the spring and which doesn't!! If you can figure that out, you can pull the other cover off and clean up the ratchet and re-lube it.
--DD
Old 10-12-2003, 05:55 PM
John Rogers's Avatar
If you can not get your original ones to work right, ones from a 924 will work okay and look the same.
Old 10-12-2003, 06:39 PM
Acox914's Avatar
Send a message via AIM to Acox914
i had some that were toast, opened em up...and yeah, that spring is sharp and uncoils like a mother! go to P.e.P. parts for some rebuilt ones.
-Aaron
"60% of the time, it works every time"
Old 10-12-2003, 07:13 PM
Biggy72's Avatar
Yup....had to get new ones too after I opened mine up....I didn't get cut, but it sure wrapped itself around everything.
Black 72 1.7 914
WSU Formula SAE
Old 10-12-2003, 08:47 PM
Toast's Avatar
Wow, you have belts that were like me huh?!? Except I dont think im as sharp as those coils. I see you are nearby my living quarters. Well, welcome to the club. You will learn alot, and get harrassed even more.
Toast
73 Yellow 2.0
86 Toyota 4X4
Old 10-13-2003, 12:26 AM
