Problem with 73 2.0L heads.
The #1 sparkplug hole is stripped. Has anyone ever used one of the sparkplug repair kits? Is there a better way to fix it with out pulling the head?
One more thing. Can the top side tin around #1 and 2 cylinders be removed with the engine in the car?
Unless there is some way to keep the metal shavings out of the head....you will most probably have to remove the head...
The guy who rebuilt my heads (a 27 year VW veteran) said that he could install a heilicoil for the sparkplug w/o removing the head. Here's how:
-bring cylinder to TDC -coat bit with oil to keep as many shavings as possible from falling in the head. -after installation, open the exhaust valve and blow compressed air through plug hole I've never done this, but he said it's how he does it. Good luck. [This message has been edited by Pritchard (edited 12-16-1999).] |
Since it is a 2.0L head I would strongly suggest taking it off the motor. I have pulled the tin off the motor still in the car, but don't think it saved much time by having to work upside down and backwards through the engine access hole. Taking the head off is the only way to be sure the tap goes in straight and no shavings are left in the motor.
I agree, the only right way is to pull it, otherwise you may end up ruining the head or the engine. Yeah maybe it can be done, but I think it is too risky to do it assembled. Maybe on an old beater VW motor that is near the end of life, but a 2.0 914 engine is too expensive to mess up.
Do it right the only time, not the second time is what I recommend. Dave PS Blowing air into the cylinder and hoping chips (that were coated in grease) get blown out the valve ports is wish full thinking. If you don't want to pull the heads, at least pull the motor (drain oil first) and turn it upside down (or rather so the plug hole is Vertical to ground) and tap it dry and vacuum it, Although this is not one tenth a good as doing it right, and pulling the head, it is probably your best shot at keeping chips out. All it takes is one little chip to score your piston, causing you to burn oil, or worse, break a ring. |
I would agree with everyone here about pulling the head. But only because you really have to drill straight on.
However having owned several abused Al heads that needed helicoiling you can do it in place without getting chips in the cylinder. The real trick is a very sharp bit, slow dril and synthetic molly. You just dip the tip of the bit in molly, slowly ream the hole pulling the bit every 30 sec and wiping all the molly off the bit. Then reapply molly and repeat until done. I've done this several times and when patient nothing will fall down. Ian |
Thanks to all.
I will be using something called a timesert. This is a threaded sleeve. It comes with a tapered tap and no drilling is needed. They say that you put a lot of oil it and it will trap all the shavings. I will try it with grease on a old VW head I have and see how it works. Anyone wants more INFO go to http://www.timesert.com The angel should not be a problem if I can get the tin off as the top half of the hole is good and the tap should thread in OK. More to come later. TMK. |
How about a Helicoil "Sav-a-Thread"?
Product number 5329-14 This is a steel sleeve that is screwed in, then a drift spreads it out to seat it in the head. The tap has about 3/4" of the M14 x 1.25 sparkplug thread then 3/8" of reamer then 1" of thread for the outside of the insert. I have used them on my car and they have never rusted, seized or come out. As for chips in the bore. Aluminium was a bit softer than the cylinder wall last time I checked and if there is a gap large enough for a chip to get between the piston and cylinder wall you should be taking of more than the head. Use grease on the tap instead of oil and fill the flutes up like your putting Cheeze-Whiz on celery. Hell, I found the nipple from a spark plug in the bore of my engine last rebuild and that was the good cylinder. http://members.rennlist.com/a914lover/ ------------------ CWP/VIR |
Well here is the latest. The #1 spark plug hole had a timesert in it. The tap would not cut new threads. It just kind of fell apart. So out came the motor. Well if I am going to pull the head I mite as well go threw the motor. So as I am only a so so mechanic and not a motor builder off it went to Jerry Woods. I am now look to remove the FI have it built up for webers if I can find some with the manifolds.
More to come later. |
Why go to carbs? Many of the posted dicsussions say that the original FI is what performs the best on the 914 engines. Do the racers go to carbs to sqweek out a bit more torque or what advantages are there? Also, it is my understanding that carbs are illegal here in California because they were not original equipment... even on the 73 and earlier cars. Apparently just because the earlier cars are exempt from having to certify smog compliance, they are still required to maintain original equipment.
Carbs are only illegal on cars that need to be inspected....so 70-73 can use them...
Carbs are the only way to go when you go to a larger bore and stroke and longer lift and duration cam...UNLESS you got big $$ to get a programable FI. The 30 year old D-Jet and L-Jet (ugh) just don't have the capability to handle the increases...kind of like trying to use a 286 computer today in the age of the Pentium III and higher systems... |
FYI The state of Minnesota just closed all state inspection sites. No more inspections. Big Brother gave in to Jesse The mind Ventura! Just think, so far we got state rebate checks from a tax surplus, repeal of the jet ski surtax, state instection sites closed, and talk of a flat fee for license plates. (Cool)
Brian is right, (don't know what happened to my last post, oh well) it's illegal to tamper/remove working emissions devices even if the car is "exempt" (Florida and Ohio anyway). I don't know if you are required to fix "broken" equipment though? Most of these laws aren't made to affect privite citizens, most likly a fix-it type of fine. They laws are geared toward large muffler and repair shops so they don't pull off working cats or FI just to make there job easier.
Those road side "star wars" things are an infra red device. It can sense the amount of certain emissions coming from the tailpipe by how well it does or dosen't transmit the infra red. Then a pic is taking and you get a nice letter "gross poluter" in the mail. Don't know if the car is pre 74 weather or not it works. Times like this I wouldn't mind having a Lil' Red Express, tailpipes straight up into the air behind the cab. Or you could buy one of those things they sell in London, has a sensor that picks up on the camera flash and instantly returns a brighter flash to over expose the film. Sold as an anti-povoratzie device, has nothing to do with all the photo-radar they use in Europe. Also there are some licence plate covers that if veiwed at an angle obscure the plate. Most states have laws against licence covers though. |
To answer Brian...Merry Christmas BTW....the "Smog Dog" operated by contractors for the California Air Resources Board (aka CARB) reads emissions from gross polluters, they are assisted by CHP who do the actual pulling over...
Now, yes it is illegal to pull smog stuff off of any 914. But as you are aware, the 70-73 914 had minimal if any smog control....FI is not smog control...it is a fuel delivery system...semantics I know.... Now back to smog dog...they will only pull someone over for gross emissions....my 914/6 with no smog on it runs cleaner than the 1.7 that it replaced....anyone driving a hot rod that emits more than the very minimal smog regs that were around in the early 70s deserves a ticket... Plus a 1970 914/6 came with carbs...my FI equipped six is even cleaner than that...at both @ idle and 2500 rpms... Just my $.02.... |
You are correct, Brian. I just went through the process (FAILED BIG-TIME!) myself. And it *is* technically illegal to change the fuel system on any post-66 car. It's just very unlikely that you'll get caught on the pre-74s in CA.
To go back to an earlier question, there are a variety of reasons that racers use carbs. One of the best reasons is that it is a requiement for some race series. In SCCA's EP, for instance, the induction is specified as "Two 40mm dual-throat carbs". So people use Weber or Dell 40s. The most common reason is to work with a big lumpy cam. The stock FIs do not like lumpy cams, particularly the D-jet which will run TERRIBLY rich at idle. A side benefit for the serious racers is that the carb setups are lighter than the stock FI. And that's a very good thing indeed for folks who will gladly spend a couple hundred bucks to save 5 lbs. Finally, the short direct intake path provided by the carbs can help high-RPM flow. This is also good for racers, since they spend almost all of their time at wide-open-throttle and high revs. However, the setup is not good for low-RPM power, since at low revs there is low gas velocity and little momentum to shove air into the chambers. In other words, it's another one of those classic low-end-torque for high-end-power tradeoffs. --DD |
If you re-read my post, I was talking about pre-74 models and the use of carbs and if it was illegal...
There is no legislation on the books that would require a vehicle to submit to a smog inspection if it is exempt....also there is no way a properly tuned, carbed 914 could be busted as a gross polluter. Carbs fail tests at idle, not at 2500 rpms....all spot checks, visible emissions tests are done on vehicles that are moving up freeway on ramps, in traffic, etc... Sooo...no way is someone gonna get busted for removing FI on a pre-74 car...if the State were to take action it would incur the wrath of every antique car club around....when the legislature passed the exemption, the unwritted rule was....any car that can last 25 to 30 years...deserves a break... |
Well I did not know how much debate this would generate. I want carbs because I like and understand them. This will be a every day car and not have a very lumpy cam. The motor will be built for carbs and mid to top end performance manly for hard street driving and autox. However with jetting and tuning they can be setup for what ever you want to do. (with in the limits of the cam, etc)
So anyone know if the kits like automation's 356/912 Weber upgrade will work on a 2.0L 914? It has Weber 40 IDF WEX carbs. What about the manifolds, linkage, etc? Thanks to all. TMK |
The 912/356/VW/1.7/1.8/914 manifolds are different....but they 914/2.0 ones are easy and chep to find....try CB Performance aka Claude's Bugs. The 914/2.0 manifolds have three bolts...some 1.7/1.8 manifolds are adaptable or already have the mods...
I did some research and found this at: http://www.leginfo.ca.gov/pub/bill/sen/sb_0251-0300/sb_285_bill_19990202_introduced.html
(a) Notwithstanding Section 44011, a certificate of compliance or noncompliance is not required for a motor vehicle that is driven 6,000 was driven 12,000 miles or less annually during the preceding two-year period . (b) A waiver shall be issued by a referee at a test-only station upon the request of the vehicle owner for a vehicle that qualifies for the waiver pursuant to this section.This is also interesting: (d) Upon the request of the department, the Department of the California Highway Patrol shall provide assistance in conducting roadside auditing, to consist of (1) the stopping of vehicles and traffic management, and (2) the issuance of notices of noncompliance to gross polluters. The department shall reimburse the Department of the California Highway Patrol for its costs of providing those services. The Department of Transportation and affected local agencies shall provide necessary assistance and cooperation to the department in the operation of the program. (e) There shall be no repair cost limit imposed pursuant to Section 44017 for any repairs that are required to be made under the roadside auditing program, except as provided in subdivision (c) of Section 44017. (f) This section does not apply to vehicles the following: (1) A motor vehicle operating under a valid repair cost waiver or economic hardship extension issued pursuant to Section 44015. (2) Prior to January 1, 2003, any motor vehicle manufactured prior to the 1974 model-year. (3) On or after January 1, 2003, any motor vehicle that is 30 or more model-years old. Just food for thought.... |
Good job....guess that means that pre 74 models CAN take off the smog stuff....at least if they do, there is no one that says they can't....or ...no one has the authority to even request an inspection....or????
[This message has been edited by mikez (edited 12-27-1999).] |
Kind of like the 55mph law that everyone ignored until it was repealed to reflect what everyone was driving. With all due respect, I think it is a non-issue for pre 74 cars....until someone gets popped, it is not something anyone should worry about...
Just my opinion. |
Great debate but in the SF bay area we have no road side smog checks that I know of and this car will only be a toy and not go far from home ever.
I found 40 MM Weber IDF EX's with manifolds and all that is needed to install on a 914 from The Performance Parts Warehouse for $569.95 + shipping. ($25.00 for 2 day air.) More to come. TMK |
"Why would you want to"....well if you had the big bucks like some and want to go fast, you could buy the programable FI like Mike Nugent did on the famous "914 Lite" (now for sale on the Pelican site)...or you can get almost the same useable HP, with carbs...for a lot less bucks=cheaper.
The only reason that you would want to stay with the venerable D-Jet or L-Jet, would be for nostalgia or Concours (sp?) events. I think that most of us are not into that. If you are...more power to ya...but not me. The 30 year old FI(s) delivered with our favorite car, can not be upgraded. I think we are ALL in agreement in that. There is no way to get more than 120 +/- 10hp out of a 914 AND pass smog with a D-Jet FI motor. I know of no FI that is currently certified by CARB to replace the D-Jet. Edelbrock bothered to go to CARB and certify an advanced FI to replace the GMC/Chevy/Ford FI on 87 to the current model year fuel injection. My search of the currrent Executive Orders from CARB can find no such upgrade certification from anyone for the 914 Type IV motor. This certification is very expensive to the FI manufacturers... The recent Clean Act, gave CARB an exalted status...the FEDs said that each State can certify pollution control systems...OR use CARB's certifications.... I hate beating this to death....but....if you want instant 4 cylinder gratification, go see FAT or Mark Stephens and get 150+HP with carbs .....for 5K and run a slight chance of getting caught by the smog dorks....Or pay 5K for a programable FI PLUS the motor to get an extra 20HP AND not EVEN be smog legal in the letter of the law... Just a few remarks from a "smog dork"... |
Thats what I like about you mike. Although I've never met you,and only talked to you briefly on the phone, you seem to be a "matter of fact guy". This is truly ment as a complement. Working in the field your in, it's refreshing to see someone of your learned back ground putting the practical spin on this subject. If there is no legal option to up grade an outdated,expensive, system with deminishing parts resources who cares. Take the bet, what are the odds.
Thanks Rich.....
And Brian also....we have come to the same conclusion from different ends of the spectrum...Carbs in MOST cases ARE the sign of a hack job. I've never disputed that....but if you get in a 914 with carbs and the rear end chases the front while dropping the clutch...odds are the engine is not stock, nor hacked... I may be an old fart, now being over 40, but I still like a little performance. The 100 hp that a stocker 914 has, does not cut with me....since CA has exempted pre 74 914s, I am taking the more liberal approach...just like people that have blown 454s in their 1923 Ford Model Ts....new mommy wagons/soccer/mobiles/grocery/getters that are driven 20-30k a year need smog control...not my toy that is driven less than 6,000 and has actually survived 30 years of CA traffic. Regards |
One point, though. You *can* get 120 HP out of a stock-displacement motor running D-jet. You have to tinker with the componentry a little bit, but it can be done.
Higher compression, tuned headers with a free-flowing muffler, and a bigger-bore throttle body should get you there. I know a 2.2-liter car running D-jet, and it works just fine. If I remember what the previous owner of that car (the one who had the motor built) said, it dyno'd at 120 HP at the rear wheels. If you figure 15% drivetrain losses, that's 140 HP at the flywheel. All it really takes is time and money... Agreed, carbs are simpler and more generally understood. But, as long as you don't put in a lumpy cam, the D-jet can indeed be made to feed a 140 HP engine; possibly more! --DD |
I'm going to side with dave here. I've got a mild Web-Cam in a D-Jet and it's easy as hell to tune. What needs to be remembered is that the grind of the cam cannot deviate too much from the stock. But the lift is all up to you.
Think about it, for larger displacement all you have to do is crank up the MPS. This simply makes each FI burst more gas. When you approach the end of that adjustment you can set it back and boost the gas line pressure a few pounds. Then repeat with the MPS. This alone would let you dial in a much larger displacement. Then there are the fun things like boring the throttle body and such. Face it the D-Jet is probabally one of the easiest Bosche FI systems to dial in. You should see what it takes on a Motronic 1.1 system! BIG BIG BUCKS! Ian |
Wow. What a can of worms.
The motor will not be a hack job but will be built for weber carbs by Jerry Woods Inc. I want carbs because I like carbs and understand how to tune them more than FI. As for the smog thing, this should not be a issue at all. The car came from Reno NV. I had to take it to DMV to verify the #'s. They did not want to see the motor at all. It will never have to get a smog check and we do not have road side checks in the SF bay area. TMK |
tmk,
Thanks for the words of encouragement... I purchased a 914 from PA six months ago. From there, it went directly to the body and upholstery shop. They are just now finishing the paint. I also, had the engine rebuilt at Black Forest Porsche for big $$$'s but well worth it! Since the PO had already replaced the FI with carbs, I was a bit concerned about going to the DMV next month to get it registered. Thanks! |
John, as long as it is a 73 or older, they just take your money and give you your registration.
If you are a member of AAA club and the registration is straight forward, i.e. no lien sales or something funky, they will do it with smile...no long lines at DMV and the crappy attitude along with it.... Good luck, glad to hear that it is almost done. Will it be ready for the 1/16/2000 San Diego autocross at Jack Murphy? The Santa Barbara/Ventura PCA contingent will be down there....look for #070 on a white 914. |
Auto crossing in January? Hell it snowed here today!! %( Anyone for a winter rallie? Last one in the snow bank wins!
What size studded snow tire will fit under a stock sided 914 on a Riviera wheel with a 28mm offset?
It depends on how much road salt they use, and how rusty your prize is. I would guess a daily driver in THIS state could take a 275/70/15 EASY!! you may have to break off some of the little brown jagged edges to prevent cuts while installing them.
No studs though. They're illegal on all vehicles! (no smog checks though) Jesse the mind had the stud ban on snowmobiles repealed. What a guy! he's swell! [This message has been edited by rich (edited 12-31-1999).] |
NO STUDDED TIRES!!!!
How are you expected to make sparks when you burn out on dry pavement? Last I heard tungsten studs were legal Nov 1 - March 31 in Ohio. Sure they tend to tear up the road when you lock up the brakes but SPARKS, man, SPARKS!!!! LOL http://www.pelicanparts.com/ultimate/wink.gif |
| All times are GMT -8. The time now is 10:05 AM. |
