Is it possible to take the fron glass off the Tach
It it possible to remove the front bevels & glass off the gauges.
I need to do some clean up work & I can't figure out how th get the covers off. Thanks. |
I've taken mine apart (twice) and the only "shade-tree" way I figured was to lay it face down on a nice soft cloth. Using a flat blade screwdriver, pry the edge of the trim ring back, working your way around the tach. Do this carefully, patiently and methodically. By doing it just a bit at a time and making as many as 3 or 4 (or more!) laps around the tach, you can eventually get it to the point where the trim ring will be able to be popped off the housing.
Caution, if you get too aggressive, the trim ring will become dented and cracked along the back. It will dent up some anyways (you'll be cringing during this process) but the rubber spacer rings will hide it when you replace it. Good Luck!
Herb '72 Tangerine 'Teen 2.4 liter aluminum handgrenade |
914 Geek
Check here for details:
http://www.pelicanparts.com/techarticles/Mult_gauge_repair/mult_gauge_repair.htm A "Sharpie" or other permanent black marker pen can be used to fix up areas of the trim ring where the paint comes off. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
