Fuel sender
I have not been able to find a pic of a fuel sender unit with the aluminum cover tube removed. I am trying to see how the slide wires inside are supposed to be and what gauge they might be. I'm attempting a rebuild. All is intact and in great condition except the slide wires. A pic of a fuel sender for a '72 914/4 would be a great help. Anyone? Thanks in advance.
Anyone?
Check page 130 of the Haynes manual.
Phil |
It figures I don't have the Haynes book. I'm going to get it right now though. Can you post the page here? Thanks
I don't have any pix but did take mine apart and clean the slide wires with steel wool and the sender worked better after that.
1971 914- original owner 1973 914 2.0 2004 GT3 2003 Mini Cooper S |
914 Geek
The diameter isn't the critical part--it's the resistance that is used.
--DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Dave - good you mentioned that. Those wires are not regular copper but are nichrome resistance wire. The resistance is probably dependent on the wire gauge though. Here's a place that sells nichrome wire http://www.wholesalepartsandfilm.com/wire.asp
Don't know anything about them and if they carry the same size wire as in the sender. |
Thanks for the info.
