Wheel lock removal without key
I need to get some junkyard wheels off a car that has wheel locks. Does anybody have a suggestion? Thanks, Pete
Plasma Grenade
73 Yellow 2.0 86 Toyota 4X4 |
Is it the type where the lock part in on the outside of the head or the inside?
You may be able to get a gator grip on it. If not, you can hammer a socket on if it is the outside kind. Or, you can find a tool guy, i.e. Snap on, Mac, etc and they do have tools made for removing wheel locks. That's the only ways I know how. Unless of couse it is the key type that you have to insert an actual key, like a master lock type key into. That is on many of the newer Porsche's and what not. These can be taken off with a chisel to reveal the lug behind it. - Brett Smith
1971 Porsche 914 1988 3.2 Carrera motor 930 Brakes / Suspension Upgrade Autothority Chip and MFS |
It is the kind that has the recessed squiggly circle on the face of it. The "key" part is a nut that has the same pattern that is embossed. Your basic Manny, Moe, and Jack. Where can I find a Plasma Grenade?
Unregistered
I've done it this way before:
get an old socket that you could live without that almost fits over the outside of the lock. Take a BFH and pound it onto the lock. Use a breaker bar to loosen the lock. Sometimes the socket get ruined, sometimes it doesn't. |
Pipe wrench and pipe to act as breaker bar on the pipe wrench.
Bunch of old cars
I agree on the pipe wrench/extender bar combo
Description: Grenade: Handheld explosives. There are two types of grenade: Human fragmentation grenades, which explode, and Covenant plasma grenades, which emit a glowing blue blast and have a nasty way of sticking to targets.You will have to ask the Master Chief 'John Spartan' where to get one.
Although, now that I think about it, Im thinkin that the plasma grenade might be a little excessive for a wheel lock removal.
peter, I have wheel locks on mine...what are the odds my key will work. how close are you to me?
Scott 1982 911 SC 1962 sunroof bug 1991 WE Vanagon CARAT WRX conversion |
ASE Master Tech - 35 yrs
tool
KD makes such a tool; it has what appear to be "threads inside it, it just grabs the slimy chrome nut on the outside and takes hold; it works; 0r you can get a YA1005c from your local snap-on guy
