Wiring Harness
Anyone know where I can find a wiring harness for a 74-1.8?
If you mean the engine FI harness and not the main harness, try RES (systems ?) a search engine should find it. Sorry I don't have a link, I know they make 2.0L D-Jet harnesses. Or look at a later Type-4 bus 77-79 for sure have the L-jet on the 2.0L motor, harness SHOULD be the same, check it out first.
914 Geek
http://www.res-systems.com
Last I checked (a while ago), they did not do the L-jet FI harness. The main chassis wiring harness should be identical. If you need the FI harness, used is probably your best bet. If there is an L-jet bus, that harness will *probably* work. --DD |
