-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=7)
-   -   rear spring replacement (http://forums.pelicanparts.com/showthread.php?t=142021)
mikester 01-01-2004 01:42 PM
Does anyone know the size of the nut that holds the rear shock on the trailing arm (bottom end)?
Plus, I can't even get the top loose...any suggestions? It's got thatnut screwed down with the top having a little flange to grip onto with something but I'm not sure what I should use. Thought about vise grips but that seems like it might be a bad idea.
Thanks for the help,
The Mikester
no substitute 01-01-2004 01:59 PM
Whoops, looks like 18 is the bolt size.
I just looked at mine--this is the bolt with the flat oval head? A 27mm socket seems to fit that nut, as does 1-1/16''.
mikester 01-04-2004 08:03 PM
Replaced them tonight with a buddy and all went well.
Springs scare the hell out of me.
ALWAYS USE A SPRING COMPRESSOR.
http://forums.pelicanparts.com/uploa...1073275399.jpg
skline 01-04-2004 08:12 PM
Good picture Mike, you look like you had some fun. Is it all back together now? Was it worth the trouble you went to? I still have the entire rear suspension off my Chalon. Just been too lazy, sick, or busy with other things to get it back together.
mikester 01-04-2004 09:00 PM
All back together and been around the block.
