BARRY MISHLER's Avatar
Oil Pump
It`s leaking real bad after engine gets warm. Engine is a complete rebuild with about 100 miles. New H.D. melling pump. DO I have to drop the engine to pull the pump?Anyone ever done it with out pulling the engine?
Old 01-27-2004, 04:51 PM
Member w/ Title Problems
Jason Porter's Avatar
You may not have to pull the engine to pull the pump, but I don't know how you're going to fit in there with the engine in. You've gotta pull the fan and shroud just to get to it, as I'm sure you know. I've never done it without pulling out the engine, just because I'd rather have some space to work comfortably. Be cause I know at some point, the "teener" is going to piss me off. The good news is that it only takes a couple of hours tops to pull the engine.
Good luck!
2023 Ford F-150 Platinum 5.0 Coyote FX4
2019 Toyota Sienna XLE AWD
Metal Building Erector, Recovering Porsche Guy
Old 01-27-2004, 05:07 PM
F4i F4i is offline
I have heard that the HD pump req. some material to be removed from the drive tab. Do you know if this was done on the rebuild?
Old 01-27-2004, 05:11 PM
Well its going up on the jack stands again. Hope it gets warm this week-end! I can`t remember if I took anything off the tang when I installed it?As I recall it fit real good, didn`t bind up.Guess I`ll get the camera out take pictures so I don`t forget how it goes back together,as I`m not a tech just a parts(good)replacer. I`ll keep you posted . thanks.
Old 01-27-2004, 05:48 PM
Its a Melling, and it leaks- Thats normal.. Those pumps are NOT round!
Jake Raby
Owner, Raby's Aircooled Technology
www.aircooledtechnology.com
www.massivetype4.com
Old 01-27-2004, 07:00 PM
OK this is not just a drip but a river,about 1/2 qt. in less than 2 min.
72914S
Old 01-28-2004, 04:58 AM
HarveyH's Avatar
On the Melling pump drive tang, From what I've heard, you have to grind 0.010" to 0.020" off the end to get them to seat correctly. If not, they can end load the cam and not seat on the case correctly. I've also heard of problems with burrs, and having to stone the end surfaces of the pump body and end plate to clean them up. (the old abrasive paper on the glass plate trick).
Harvey
Harvey
Old 01-28-2004, 05:25 AM
Bleyseng's Avatar
Send a message via ICQ to Bleyseng
Some mill a grove on the back of the pump to accept a rubber O ring so it won't leak.
Geoff
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression)
www.914Club.com
My Gallery Page
Old 01-28-2004, 07:44 AM
on the jack stands now
Well if the weather cooperates,got a friends motorcycle jack, looks like this will work great to lower the engine & trans. I hope I can change out the oil pump this weekend. I`m going to check out the H.D. pump to see what went wrong. I may just put the stock pump back in.I was getting about 40 lbs. anyone know what the stock one should put out?
Old 01-29-2004, 05:35 PM
40 lbs when???? at hot, cold?? what weight oil were you running...
the only fix for a Melling is to remove it and throw it as far as you can and hope that no one ever finds it again! The tolerances in those pumps are so far out that its impossible to blueprint one.
Jake Raby
Old 01-29-2004, 09:38 PM
mike95125's Avatar
Layperson question: What do you do, and how do you blueprint an oil pump?
AKA: Dr Evil on the 914World forum, need your tranny rebuilt, or want a "How to rebuild your transmission DVD" set? PM me.
-74 914 with 74 2.7 CIS
-74 VW Bus with modified 3.1 corvair engine and 3.0 CIS fuel injection system.
-74 BMW R90
Old 01-29-2004, 11:13 PM
914 Geek
Rule of thumb for oil pressure--when warm, you should see at least 10 PSI per 1000 RPM. Up until the pressure relief valve opens.
Blueprinting an oil pump is a lot like blueprinting an engine. You measure everything (but everything!), set the clearances up just right, and possibly even match up the inlet and outlet ports to the passages in the crankcase. Yes, this means machining stuff.
--DD
Old 01-30-2004, 05:26 AM
