need to refurbish tank?
I have read several posts about refurbishing the inside of fuel tanks- mine is out and could be done if necessary. The tank is in very good condition- and has only a slight rust along parts of the inside. There is no significant pitting or flaking. I am replacing the fuel screen (when it gets off backorder from PP) and fuel pump/filter were replaced along with the fuel lines. This 914 is getting ready for a Raby built 2270 over the holidays.
Do you guys think this is serious enough to go to the trouble of coating the tank? Is it enough to possibly give me problems within the next few years
Easy to do with the POR-15 kit. Takes a couple of evenings (have to wait for things to dry).
Qarl |
i've never done it but it would be easiest now, PITA later
73 914 restoration project 73 914 2.0 CIS #80 74 914 1.8L L-jet 83 911SC |
I took mine to the local radiator shop (the good one) and they striped the inside and out and then recoated it for a couple c-notes. Cheap enough not to pass up.
'75 1.8 -->1911 |
Ok- you guys convinced me...plus it is only $50.
I will call POR- Thanks for the help. |
POR kit worked well for me and the inside of my tank was a lot worse than that. The car had been sitting for over 15 years with a 1/4 tank of gas (or should I say jello) in it! Just use the warmest water you can with the cleaning agent.
1971 914- original owner 1973 914 2.0 2004 GT3 2003 Mini Cooper S |
por kit? whats that all i heard you need to do is take the tank out soak inside and out with rustremover and then paint if needed
what do you guys use to (seal) it with |
POR has a sealer in the kit. A rubberized, rust sealing paint that you swish around the inside to create a new impervious lining inside the tank!
Qarl |
gimme
Blue 73' 914 1.7 |
Banned
This might help you (don't tell anyone I posted it).
finished
I finished the project using the POR-15 kit. It is pretty easy to do- but the process does take a while due to all of the steps (cleaning and rinsing) that you have to go through. Thought I would post an "after" pic for closure.
